Sabertooth Kangaroo icon Sabertooth Kangaroo — Movement panel enabling Kangaroo & Sabertooth encoder-based speed/velocity control, UART/PC serial options, tuning and encoder setup. Try it →
the sad part is i am using a ACER ASPIRE ONE on robot and my cell phone (verizon note 2)is 4 times faster and 1/3 the size
Netherlands
I think I'll win in size and speed by linking this one:
Click me!
Though in comparison with the rasberry its super expensive, it might need some extra stuff to run but, still WIN(ish) because it can run windows 7 and its only 10 x 7.2 cm (3.9" x 2,8")
Winning in my book is a good balance between cost, size, power and lack of waste. If the board is too powerful and costs twice as much as a board that's just about right but slightly bigger then the larger board is going to win in my book.
Provided it fits in the robot, is the cheapest possible for the required system resources to run whatever needs to be run and is energy efficient enough not to have to recharge the robot every 15 minutes then it's in the win column.
Especially with EZB, all the board needs to do is run Windows XP/7/8 smoothly, have full voice recognition and text to speech capabilities and run ARC smoothly.
If it could also run the latest Crawl to Booty - Bee Bops on the highest resolution ever thought of whilst streaming 1080p HD video content over a wireless network then it's like putting a Ferrari engine in a Zundapp Janus
We're ALL winners on this Forum, when we share our projects and positive feedback:)
Thumbs up for irobot58's comment.
#16
All VIA pico-itx series are really small 3.9" by 2.9" but that one only has a 1 ghz quad core
there one here is 1.7 ghz I3 processor with up to 16 gb memory,but price is $379 and size is 3.9" by 3.9"
D33217GKE Specifications Compatible Cases See our Compatibility Database: Mainboard Matrix, D33217GKE
Mfr Part No. D33217GKE
Processor 1.80 GHz Intel Core i3-3217U Chipset Intel QS77 Express System Memory 2 DDR3 1600/1333/1066 SO-DIMM Up to 16 GB of memory Graphics Intel HD Graphics 4000 Expansion Slots PCI Express Mini Card (full height)
PCI Express Mini Card (half height)
Onboard IDE None Onboard Serial ATA Internal mSATA port Onboard USB 1 USB port via pin headers Onboard LAN Intel 82579V 10/100/1000
Onboard Audio Intel High Definition Audio via HDMI v1.4a interfaces Back Panel I/O 2 USB 2.0 ports 1 LAN ports 2 HDMI ports 1 19V DC input jack
Onboard I/O Connectors 2 USB 2.0 via 2 pin headers 1 Internal DC power connector
BIOS Intel BIOS, Support for Advanced Configuration and Power Interface (ACPI), Plug and Play and System Management BIOS (SMBIOS)
System Monitoring & Management Fan speed control, Voltage range monitoring, thermal range monitoring, fan activity, and one processor fan header/
Operating Temperature 0degreesC~55degreesC
Form Factor NUC (10 x 10 cm)
pico-itx motherboard with I3 processor
