Sphero Movement Panel icon Sphero Movement Panel — Control Sphero via Bluetooth in ARC. Detects two COM ports (one connects); requires deleting and re-pairing after disconnects or reboots. Try it →
Rc Tank Conversion
Well, I've finally got the RC tank stripped down to start turning it into a bot. The drive-train of this thing is actually fairly sophisticated. It has separate springs (shocks) for each road wheel! I've stripped out the old RC control board for re-purposing, and there is a huge open space in the hull for the new electronics suite. So far I've identified all the wires for the LED lights, drive motors, turret AZ/EL, and the trigger for the airsoft gun. I plan on replacing the LED lights with IR LED's, since the wireless USB camera that's gonna be attached to the main armament as a coax see's into the IR spectrum. Gotta figure out how to add a GPS to the EZ-B.
https://www.flickr.com/photos/35342683@N04/7624139348/
THANK YOU:)
Helz, once you get the wiring done, add the Hbridge as a control, and then one PWM control connected to each of the first 4 digital pins. After that I added a joystick control and could drive around the room.
Success! I have a rolling chassis! The left track keeps throwing when I do a right pivot turn though. If it was a real tank I'd check and adjust either the track tension or the state of the drive sprocket. :)
