Lidar-Lite Laser Module icon Lidar-Lite Laser Module — Laser Lidar-Lite ARC control reads distance, velocity and signal strength (0-40m+) via EZ-B v4 i2c, setting EZ-Script vars for robotics Try it →
Reading Mpu9150 From Python
Hi all,
Is there a way to get sensor readings from an MPU9150 directly in Python? I've tried writing its values to a file and then reading from that file as it's being written into (to develop a live interface), but that crashes when both ARC and Python are trying to access the same file at once.
Python was able to get the camera image data just fine. Figure there must be a way to grab sensor data as well.
Thanks, Michael
I would use the Mqtt broker and client plugins to have ARC push the data to an MQ topic, and then use a Python mqtt client to read the topic (dozens of sample clients if you search python mqtt client).
If you are using Python there are few options available.
If is something simple i would go with a Http Client / Server solution.
ARC side (Http Client):
you can use HttpGet function.
Client calling a server mydesktop on port 8899
$quit=false
$CompassHeading = 0
repeatwhile($quit=false)
  #read the imu here
  #let's simulate a rotating heading
  $CompassHeading = $CompassHeading + 1
  if ($CompassHeading>360)
    $CompassHeading = 0
  endif
  print("Sending heading=" + ToString($CompassHeading))
  HTTPGet("https://mydesktop:8899/imu?heading= " + ToString($CompassHeading))
  Sleep(1000)
endrepeatwhile
Python side (Server)
#!/usr/bin/python
import time
from BaseHTTPServer import BaseHTTPRequestHandler, HTTPServer
from urlparse import urlparse, parse_qs
quit = False
PORT_NUMBER = 8899
#This class will handles any incoming request from the browser
class myHandler(BaseHTTPRequestHandler):
	#Handler for the GET requests
	def do_GET(self):
		try:
			url = urlparse(self.path)
			path = url.path
			query = parse_qs(url.query)
			if path=="/quit":
				print("Got quit")
				quit = True
			elif path=="/imu":
				self.send_response(200, "OK")
				self.send_header("Content-type", "text/plain")
				self.end_headers()
				self.wfile.write("OK")
				print("We got heading=", query.get('heading', None))
			else:
				self.send_error(404)
		except:
			self.send_error(500)
		self.finish()
		#self.connection.close()
		return
try:
	#Create a web server and define the handler to manage the incoming request
	server = HTTPServer(('', PORT_NUMBER), myHandler)
	print 'Started httpserver on port:', PORT_NUMBER
	#Wait for incoming http requests
	while quit == False:
		server.handle_request()
except KeyboardInterrupt:
	print '^C received, shutting down the web server'
	server.socket.close()
The Python 2.x code runs both on Linux and Windows, creates a web server on port 8899 (PORT_NUMBER) and handles two requests:
  1. /quit
  2. /imu?heading=nnn
you can create a thread to handle the server requests:
once you get the values you have a lot options.
