Openai Text To Speech icon Openai Text To Speech — Convert text to dynamic, real-time speech with nine expressive OpenAI voices-natural, varied, accessible robot communication. Try it →
I want to receive ON OFF messages from Openhab to turn on Inmoov scripts. Binary array is unchecked and this is the script on the mqtt line . But its not working with a "Error on line 1: Variable is an array: $awaiting_your_command"
if $awaiting_your_command = ("ON") ControlCommand("Script Manager", ScriptStart, "awaiting your command") endif
@GregC
$awaiting_your_command is an array variable. you need to specify the index e.g. array position
#compare position 0
if $awaiting_your_command[0]="ON"
endif
#compare position 1
if $awaiting_your_command[1]="ON"
endif
So it looks like unchecking Binary array then testing for a string is what works.
if ($awaiting_your_command = "ON")
endif
I think this needs to be on the help page. There are send examples but no receive ones.
On the openhab side item Switch inmoov_awaiting_your_command "awaiting_your_command" (inmoov) {mqtt="<[mosquitto:robot:state:default::]", mqtt=">[mosquitto:robot:command:ON:ON],>[mosquitto:robot:command:OFF:OFF]" }
Now openhab and "BOB my inmoov" can talk.
