Sound Movement icon Sound Movement — Stereo mic sound localization triggers left/right scripts to control robot movement, enabling directional responses (turn/move) to audio. Try it →
About the only way is to open the bottom of the EZB and remove the speaker.
By doing this, you will remove all sound from JD directly. You would have to play your sounds through your pc instead of through the ezb.
Deborah, do you mean the startup sound? Or are you hearing some form of message?
