Train Vision Object By Script icon Train Vision Object By Script — Train camera vision objects via controlcommand(), attach camera, start learning, monitor progress, and return object name for scripts. Try it →
Recording audio to send to AI platform
Recording Audio To Send To AI Platform
How can I record audio from the microphone for an extended period, such as up to 10 minutes? I want to capture a person speaking, save the audio as an MP3 file on my hard drive, and then send it to an AI platform for a response. I have attempted to use the Microphone skill in Synthiam ARC, but it failed to record anything and does not save the audio to my hard drive.
Could you provide guidance on how to achieve this functionality?
Microphone by Synthiam
Record audio from your PC mic, auto-trigger and edit sample rate/effects, then play or export recordings to an EZ-B v4 SoundBoard for robot playback.
I can get a reasonably good debate response from Chat GPT using a prompt such as this...
I want you to act as a debater. I will provide you with one person’s discussion on a topic and your task is to research both sides of the topic, present valid arguments for each side, refute opposing points of view, and draw persuasive conclusions based on evidence. Your goal is to help people come away from the discussion with increased knowledge and insight into the topic at hand. You may address the speaker by name. Here is the first speaker.
At this point, the speaker's talk translated to text, needs to be added.
