EZB Connect By Name icon EZB Connect By Name — Discover EZB WiFi controllers by name, auto-bind connections, avoid IP management; live discovery and multi-EZB support for ARC. Try it →
Josh and others have mentioned Dynamat sound proofing matting helps a lot
i am using air solenoids on some,on others i make my own servo's that i found out noise is a lot less and dynamat is great also
yes DAVE thats what i use to make my my own gear boxes and using a servo board
pneumatics Are nice and strong. They work great but were also noisy. They hiss and then you have the air compressor noise.
Not using a compressor,only a small tank,another item is using lego design type using a motor and syringe. So almost no noise and only reason is that on my johnny five project i need it to match johnny five solenoids on the head design,if you look at my project its on page 3
my johmmy five project its the ones in orange,ones i got is stainless steel and painting them orange to match them
Only need a small tank and can add a compressor like lego servo style to fill tank when get empty
