Hello
is an easy way to Kinect Relay Module to EZ-B
Omron HVC-P2 (Second Camera)
— Windows ARC plugin for Omron HVC-P/HVC-P2: Python-based face/body/hand detection, gaze, age/gender, expressions and recognition; dual-camera support.
Hello
Did you mean "Is there an easy way to connect a relay module to the EZ-B"?
If so then yes. Look for Josh's Saltwater Tank project, he has used some relays on that. From memory he used a TIP transistor circuit to energise the relay.
Or you can simply buy a ready made module that is opto-coupled and isolated. You may connect it to any digital output from EZB
Module with 2 relays
