Wowwee MIP Movement Panel icon Wowwee MIP Movement Panel — UART-based EZ-B/ESP32 skill to control WowWee MIP, enabling ESP32-Cam camera support and flexible battery-powered integration. Try it →
Relays Turn On, But Not Off
Alright. My dewy build is almost finished, but I have hit a problem with the relays I'm using. They require at least 1.5v to activate them, and then nothing to deactivate them.
Using a set digital control, I can turn them on, but turning the control off doesn't deactivate the relays.
Why would this be? Does setting the digital port off not set the voltage low?
How else can I activate them and deactivate them with the ez-b if not in this manor?
#25
Jeremie - would you share the link to the relay board that we used on bimbo?
#27
@Alan... I think It gets the 5V from the power pin (I use a couple with my inMoov using 6V and it is fine)... The signal pin is just the trigger (some sort of mosfet maybe?). Anyway 3,3V seems to do fine... I have been using these plug and play for a few years now in various projects with no issues... Come to think of it so has Steve G...
#28
Oh, yeah, I didn't notice that they connect all three pins to the digital port, that makes sense. I guess if using with a 7.4 lipo would probably want to put a 5v regulator inline.
I am on my phone now so can't easily check, but I noticed in the data sheet download zip file that there was also a schematic. Should check to see if it has a mosfet or transistor on board.
So will the resistor work? Or is a diode in the signal line needed?
#30
This is a picture of the relays I tried to use and had the same problem with it staying on. I put a 5 volt supply to it, and gnd to gnd on the ezb and the signal to a port.
I needed the relays to work for the project so I made a transistor switching board that Rich posted. That got me running. I don't have the spec sheet, there was none when I got it on ebay.
I know others had tried to make this style relay work, but I never heard a final fix.
#31
I put a 10k ohm resistor in the signal line. It inverts the trigger method. I put power on, it turns off. I put digital off, it turns on.
Before it would only partially turn off, not enough to disengage it.
#32
I won't be able to test it until late this week, but maybe a 10k resistor, sig to ground will fix it?
