Synbot Plugin icon Synbot Plugin — Synbot plugin for ARC: local Bot Server chatbot integration with SIML dialogs, ControlCommand API, multi-language, learning and emotion support. Try it →
Remember Clicling Sound Found It
i had a servo whit a clicking sound in it.there where more byers who has this sound. so i thought it was normal,till today when i connected all in the robot. power up the robi and there was smoke,lucky i had connected the on/off swits. the damage hopefully is only wires. now i have to wait a hole week for a wire from less then 1 gram 7 cm long tired mad so never use a servo that makes any not normal sound.
oh no! this is on the Robi? hat sucks!
yes in the righ upper leg was 1 mm wire exspossed.. its the desig ,the way you have to close the servo. i hope its only two wires.
