Command Duplicator icon Command Duplicator — Duplicate and synchronize commands from one master EZ-B to multiple slave EZ-Bs for simultaneous, mirrored robot actions. Try it →
Remotely Power On Or Off Revolution Robots?
Hello - I am mostly paralyzed from Lou Gehrig's disease and I won't be able to turn my Roli on or off to use it when I am home alone. My house is fully automated so I can be left alone for a few hours at a time. Is there a plan or a way to do this seemingly simple task? Robotics for the disabled is a largely untapped field. I performed a few searches but came up empty. Thank you in advance for your replies.
But it needs to be triggered remotely that's the most important part to be completely remote
#26
Further details on this circuit
Something along these lines. This one even allows the EZ-B to turn itself off. This is just an example, there are other circuits which could also be used. You can also have a remote RF controlled switching circuit run along side it to simulate the push button for remote operation.
Hello I found a Simple RF Receiver that should be small enough to fit into most any robot just use a small transistor on the output should do the of a simple remote power switch
#28
That is really slick @Wolfie. Of course the question that comes up is how much power is the receiver drawing, and is it any less than just leaving the EZ-B on (for v3, almost certainly, but v4 goes into low power mode when ARC is not connected). I am sure there will be uses for this in any event. Cheap enough I will probably oder one just to play with.
