Kinect Body Control icon Kinect Body Control — Control robot servos with Microsoft Xbox 360 Kinect body tracking; map joints to upper/lower body servos with smoothing and pause control. Try it →
Removing The Ic
Removing The Ic
Folks, I need to replace the IC on my EZB. I received a replacement chip, and I assumed I would need to you an IC "puller". However, I don't own one, and before I make the run to a local electronics shop to get one, I want to make sure that is the appropriate method. It seems like there is little clearance between the chip and the Bluetooth socket.
Help please. Thanks.
Use a small flat head screw driver. Start at 2:30 because that dude likes to talk.
Ha ha , man I hope im not that bad in my videos!
