Tiny Yolo2 icon Tiny Yolo2 — Real-time TinyYolo object detection for ARC Camera Device: tracks 20 classes, populates camera variables, triggers tracking scripts, 30+ FPS in HD. Try it →
If you use a TTL usb adapter, yup:)
Connect the RX and TX lines off the TTL usb adapter to the EZ-B plug and voila
Gibraltar
Excuse my ignorance Will EZ B still connect to ARC for programing i want my bot to be autominous so i don't mind not having BT control over it
Netherlands
Twitter YouTube
Yes, My omnibot has a USB->TTL adapter i got from SparkFun and it works just like the Bluetooth.
Gibraltar
hay niek could you give me link please:D
Gibraltar
Got rx/tx connected to usb, soild LED, could you tell me how to find com ports in windows xp or what to do to connect to ARC
Netherlands
Twitter YouTube
Go to Start menu -> Devices and printers.
At the bottom, you should see a 'USB COM port (COM...)'
Niek ----What is the part number or link for the USB->TTL adapter you got from Sparkfun?
Do you need to also hook up the USB->TTL adapter GND to the EZ-B GND? Or are you only using the Tx and Rx?
