Sharp IR Radar icon Sharp IR Radar — Radar-style Sharp IR scanner for EZB ADC: sweeps sensor, displays distance dots, logs ADC voltage, and can steer/avoid obstacles via Movement Panel Try it →
No, connection information should be maintained without power while you wait for the new batteries, and servo calibration doesn't have anything to do with the power supply.
thank you alan
@nomad... swapping out batteries is the equivalent of turning JD off with his switch, both cut power to the robot.... All servo settings are saved on your computer, not the ezb...
sorry late replay rr
am i lucky then.
