Rafiki Front Bumber icon Rafiki Front Bumber — Rafiki front bumper plugin: reads 4 proximity sensors via serial, updates ARC variables, blocks motor movement toward detected obstacles for SLAM Try it →
Are you using something like C# to query?
You could ask for the variable something like this....
bool success = true;
int cnt = 0;
List<string> values = new List<string>();
while (success) {
  send(string.format("print($variable[0])", cnt));
  string val = readLine();
  if (val.contains("Index was outside the bounds of the array.")) {
    success = false;
  } else {
    values.Add(val);
    cnt++;
This was really a request from STeven from Roborealm so let me check with him.
So when the Array is created inside ARC it really is multiple variables with the index at the end and you use the print command to read the variable
If that's true my initial response to him was correct.
I wanted to verify if my logic was sound.
A second question I had for myself was does EZ-Script support Multidimensional or Jagged arrays?
Thanks for your help DJ
if this is for steven, tell him that I will be creating a "dump variables" option for him
I will let him know what you said.
As of now you can in fact get the arrays from the RR EZRobot_variables module into ARC.
It was the retrieving them that prompted the question from STeven
Thanks
I have just implemented a DumpVariables() function which will output a list of all variables in ARC and their respective values. It will be included in the next release which is now postponed until after tomorrow's testing.
Thank you very much DJ.
Your hard work and that of your team is really appreciated.
