Lidar-Lite Laser Module icon Lidar-Lite Laser Module — Laser Lidar-Lite ARC control reads distance, velocity and signal strength (0-40m+) via EZ-B v4 i2c, setting EZ-Script vars for robotics Try it →
Revaluation Six Balancing
Can any one tell me if the Revolution Six will balance and walk on only four legs. I want to get one and change the front to sets of servos too arms.
Don't want to get some thing I can't use, I'm 13 and can't afford to waist money.
No one has one yet, but there are lots of examples of 4 legged robots walking and balancing just fine using basic servos... That being said, 6 legs would make for a smoother gate, but 4 will still work... I am sure Six would be able to do the same... ARC software should even make programing it, that much simpler as well....
Thanks rryerson this will make the choice a lot easier
With only 4 legs, you will want it to walk with one leg at a time to maintain good balance, although you could probably program a faster left front/right rear then switch gait for faster movement at the risk of some stability.
Lso note, the six will have 6 extra easy bit mount points (they don't show in the current videos because they were shot with a prototype) so you could have 6 legs, 2 arms, and 4 more bits.
Six has 12 connections, so yah you can attach arms as well.
I know how you feel @rangatron. It's hard to afford this hobby.(13 also)
It's hard to afford this hobby at 33!
I can't afford this hobby and I make the stuff!:D
@Technopro , @rangatron When you're 13. all the money you have is what we refer to as disposable income (meaning, you can spend it all on whatever you want)... When you become an adult and have to pay your own bills (like a mortgage, electricity, heat etc)... most of your income will now go to those expenses... Most of us have less money to spend on our hobby now as an adult then we did back when we were your age... Spend while you have it, is my advice...
