Advanced Speech Recognition icon Advanced Speech Recognition — Azure Cognitive Speech recognition for ARC with custom API credentials, scripting, language control, and text output for detected phrases Try it →
Revolution: Jd Not Charging
I have viewed the related tutorials with no luck on how to correct this issue. I've just assembled 5 brand new, Revolution: JD robots. I attempted to charge them all yesterday. All of the Link-Man chargers lit up, except on one of the robots. At first I thought it may have been a damaged charger, but when I connected the other chargers to that one robot, none of them lit up. Could there be an issue with the wiring of that one robot?
The wire connects directly to the battery, so more likely a bad battery or broken wire. You can open JD and remove the battery for visual inspection to make sure the wires aren't broken and the battery is now swollen/puffy.
