Camera Snapshot icon Camera Snapshot — Save camera snapshots to 'My Robot Pictures' (Pictures folder), manual or timed (0-100s), and trigger programmatically via controlCommand. Try it →
Rex Drive Motor With Optical Encoder
I just received in the mail today a REX motor With encoder and I was wondering if anyone knows where I can get a 5 pin plug and lead to suit the encoder pins on the motor
I have looked but cant seem to find anything that will fit. I will need something to connect the encoder to a Kangaroo/Sabertooth combo
Steve
Hay Steve, I'm using this motor and encoder on the waist of my B9. It's pretty quiet and I really don't notice it. I have some pictures of it installed over in my project thread here on the ez robot forum.
That connector pin on the encoder accepts a common 0.1 Molex connector and housing. Found at places like Digikey, Mouser and Great Plains Electronic. Look here
https://www.greatplainselectronics.com/categories.asp?cat=70
I don't know if the crimpers you mentioned will work with them but I bet they will.
Hi Dave,
I intend to use the motor for the same application as you, (not really a coincidence ;)) I'm in the process of pricing a Molex crimper and some alternatives as we speak with my local Electrical Wholesaler. The Molex one is pretty pricey eek I need to check all the crimper's I already have too, I may have something that will do the job. I will have to wait for the crimp terminals from Element14 to turn up so I can do a test crimp.
Steve
I found an excellent low cost crimper, well, low cost compared to the Molex crimper. The Molex one would have cost me nearly $500 eek Hard to justify with the amount of work they will do. The other one is made by Engineer, model number PA09 $75 and they work a treat. Very happy with them.
Where did the wheels come from that are shown on video ?
@rb550f, The wheels are standard 6mm axle trolley wheels that have been customised.
It needs the customisation because my robot locomotion platforms can move with great precision so I need to reduce wheel slippage to an absolute minimum else movement errors start to be a problem. This type of end wheel design helps keep wheel slippage down to a minimum.
Tony
