Hitachi-LG LDS Lidar icon Hitachi-LG LDS Lidar — Hitachi-LG LDS 360-degree LiDAR driver streaming scans into ARC NMS for obstacle detection, SLAM use, Arduino hookup, config options and variables. Try it →
Ireland
@bborastero one possibility only if you have lots of space is to use two RGB arrays then you could use one array for left and one for right I am considering this option at present but I have plenty of space
@bborasteroyour script is good... it will change the color randomly. what you can do, is use the ServoSpeed() command to add a little bit of smooth transition between random colors. Such as this...
servospeed(d9, 1)
servospeed(d10, 1)
servospeed(d11, 1)
:loop
PWMRandom(d9,0,100)
PWMRandom(d10,0,100)
PWMRandom(d11,0,100)
Sleep(1000)
goto (loop)
I set the sleep() to a longer delay so you can wait for the transition to complete. The ServoSpeed() sets the ramping between two different PWM positions. Here is a video example...
This shows the PWM for the servo...
This shows how the ramping occurs...
Ok, that is something I did not know... Nice tip!
Gibraltar
thanks @DJ Sures always good to hear from you :)
