Interface Builder icon Interface Builder — Create touchscreen robot control panels with buttons, joysticks, sliders, camera views and scripts; multi-page fullscreen UIs for PC and mobile. Try it →
I am liking these new videos you put up today. Very professional feeling.
It's been a while! It's funny because it's the same format as the old ez-robot videos when I worked out of my basement. I'm glad you like them:D
It's time for lots of tutorial videos now that there are lots of features... and more hardware to come as well.
So during this demonstration towards the end you coded the robot to say see my fancy animation or something to that effect. However it did not say anything in the end video? This is not meant as criticism but I noticed today after updating to 4 18 software during a brief showing of my robot to some children the robot would accept the move forward command but not actually move foreward. When running the script manually from the script editor it worked every time. The only reason I caught it was because when I give the robot a spoken command " move forward" it repeats back to me the said command and then acts upon it. Any ideas?
For what it's worth none of the spoken commands worked, yet did dictate what the spoken command was. Hmmm
@kamaroman68 ... It's just the way he did the video.... maybe he removed the "say" command line before showing the result with JD? Maybe it was videoed in segments where things like scripts changed between segments?... It is just a video and you can make videos do anything you want them to do... If it works in the real world it's not really that much of a big deal with this slight oversight, right? Cut the poor guy some slack... He's wearing a million different hats at ez robot...:)
Everything works fine in my projects with ARC so how the video turned out doesn't concern me at all...
Remember your robot is only going to move forward if you have set everything up properly... programming, mechanics, power etc.... When my bots don't work as expected it is 99.9% usually my fault...
So again my robot worked fine yesterday , today after new software download it does not. There are no new mechanical or programming changes. I also said there was no criticism intended so I'm not sure where cut the guy some slack is coming from. But thanks for the reply Richard
  1. There are no reported issues with the latest ARC for moving. Please check your robot configuration and wiring. Also check your program to verify it is setup correctly. Perhaps provide us details about what robot you have, what program you are using, and if it is a stock project, what has been changed would be helpful. If you'd like me to look at it, share the project and i'll test it.
  2. Correct, the robot does not speak anything in the end of the video even though I coded it in the example - good eye, or ear in this case... However, i'm certain the point of the video is still effective. If not, I apologize. There are no immediate plans to redo the video to add the audio.
Thank you both for completely reading my entire post. I will again refrain from posting on this site.
