Neopixel Blaster icon Neopixel Blaster — DIY NeoPixel Blaster for ARC - open-source controller for up to 8×80 LEDs (640), port‑0 onboard RGB, color control via ControlCommand Try it →
Right Ankle Servo Calibration
I am just working with the JD Humanoid for the first time today, I am able to connect the robot with my computer. Through the process of calibrating the servos, my JDs right ankle has a twitch? Is this normal? Is there a simple fix to this issue. I've uploaded a video of the issue as well. Thank you in advance for your response.
Ah, looks like you got the dancing version!
Joking:)... That servo is indeed damaged from factory. You can always check the cable connection going to the EZ-B to ensure it's secure. Otherwise, i believe it's the servo. Contact Us and we'll have that resolved for you
Oh - and second question. Can you verify if the servos read HDD or HD on the stickers? Thanks!
