Camera Click Servo icon Camera Click Servo — Interactive camera control for ARC: click-to-center and edge hotspots to pan/tilt servos, adjustable fine-tune and multi-camera support. Try it →
Hi there I need to use wired lan (RJ45) to control my ez-b on a long distance. I've searched the forum for solution but haven't found.
How can I replace the bluetooth with wired lan and how long RJ45 cable can I use? I've read that RJ45 could be up to ~90 meters (295ft) but will ez-b be able to read the signal at that length? Thanx :)
The WIFI BOARD is $35 AND has -PHY AND +PHY needed for RJ45 and about $5 in parts you have both just like a WIFI router
I mostly design electronic circuits and networking is super easy for me
I did make a tutorial on my design and got all my parts in,mostly whats needed is a SERIAL WIFI board a few resistors and special RJ45 with a isolation transfomer built-in.
I have a lot of projects once i get back in a few days ,good news no more work.
SO will be making it soon.
Ok, it might be interesting to have both and the option to choose.:)
