Sabertooth Movement Panel icon Sabertooth Movement Panel — Sabertooth movement panel: control two motors via Simplified Serial with variable speed sliders, movement buttons, and serial port options. Try it →
Roborad - My Next Bot
So this will be my 3rd robot entry. While I am still working on B9, I have some down time and a new EZ-Kit on the way, so I decided to start my next project. A little different from both of my two previous bots, in this one I am combining a Robosapien and a RAD to make RoboRAD.
I removed his legs and just set him in the RAD base for this pic, but it gives you the idea. After creating two bots wherein I had to build everything (arms, claws, etc.) I wanted to try out the EZ-B with one of the supported platforms - less building and more programming. I do want to make RoboRAD a cool bot - new paint, new functionality, cool devices. But I think this will be a fun platform to start with. I will keep you posted as I proceed. I think my next step is to remove the RAD labels and run it through the dishwasher. Then I guess I am going to lose the cupholder (like Josh did on one of his MechWarrior bots). More later.
Yeah, I'm anxious to see Sam's progress as well. Have not heard from her in a while.
I got the legs removed from Robosapien...he looks kind of sad. I think I am going to use the same 12V battery I used in B9 - it works great in these RAD bases and should give me plenty of power for some of the stuff I want RoboRAD to do.;)
If you want to work out a trade or somthing you know I have another identical battery:)
Hmmmmmmm...me likey that idea. Got something in mind? Text me...
Most Epic Goody Box EVAR!
2 x Defender Automatic Airsoft guns 12V 7ah YUSA New batt w XT60 gold connector kit Roll of sound deadening matt , yes thats right a roll! 4 extra long servo ext cable 6 12 inch long servo cables Modified dart blaster case Ezb cooling kit, 40mm fan Velcro EZ cam mount Woohoo
Dude! You rock! I will get yours together tonight and let you know what is coming! It will soon be time to start working on Gunslinger Bob Mua Ha Ha
#15
RoboRAD project list: MP3 with lots of music and nice speakers EL wire neon lighting Plasma Ball brain Camera head on pan/tilt mount Mechanised tow hook so he can tow a cooler/trailer around
and open to other ideas for cool functions!
