HMD-16 rev:01 2007 does not show correct pinout for IR connector... gnd is there
Can you advise thanks!
Joystick (Direct Input)
— DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback.
hi i found the vcc power.
and here the ir
here another pic .i think its better to see.
your board and mine
Hey @Nomad My board is similar to yours, is the one marked IR-OUT (right next to the Gnd) the one I need? I just figured it was like positive to positive, not like in to out like stereo equipment but I guess that makes sense. Can you confirm this for me? I don't want to ruin any of my stuff
the pic whit the red cirkel on is your board. and it seems that the IR always is in desame place,also on other boards. we can ask other members there opinion too. incase some bad happens ,i have a spare board you can have .
Hi Artron007, if you look at both boards, on the head connector (top center of board) where nomad18.08 has circled you will see the grd, below that also circled in the same circle is the Vrx, now if you look at the third pin from the left (which is IR Out) directly below it is a pad of solder that you can use to connect to the IR Out, another way to find it is looking directly to the left of the p2.5 label. I hope this helps, sorry I'm not posting pics right now but I'm not anywhere near a board to do so. I will try to upload a pic later.
so the smal red cirkel is Vrx ? this pic maybe helps
Hi, Take a look at this, this is the way it is laid out, look at other boards and you will see that the pins are the same, but the placement of the solder pads are placed differently.
