TCP Clients icon TCP Clients — Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections. Try it →
@Steve_G, Thanks for the detailed explanation. This is great and very helpful. I have to admit I haven't even tried out the Auto Position control yet as I've been spent much of my time wrench turning building the robot. Today I plan to try to learn the Auto Position control as it seems perfect for my B9 robot arm. This and some of the other advice given is very timely and will help a lot with my learning curve.
You should turn this into a Tutorial. :)
Hi guys. I am getting the hang of it. I would like to thank Steve G and B Houston. I would like to get a few frames from the project you made so I can see how to set up mine. Thank you to the whole community. :)
