MPU6050 Accelerometer Gyro Temperature icon MPU6050 Accelerometer Gyro Temperature — Reads MPU6050 gyro, accelerometer and temperature via I2C, initializes and returns data on-demand to EZ-Script variables using ControlCommand RunOnce Try it →
Robot Arm On Wheels
Robot Arm On Wheels
Here is a cool little arm on wheels I bought from ServoCity, its called the Stacker. I ordered the Stacker and the stronger lift and grip servo but not the wheel servos, EZ-B servos work just fine. I can lift a full 12oz beer with these servos with a little rubber tape on the gripper so the beer does not slip. The compartment under the arm holds the EZ-B and battery pack just fine. Also its made from 1/4" ABS so it can be drilled to hold other accessories like the camera, sonar etc.
Here is the link to the Stacker. https://www.servocity.com/html/stacker_robot_kit.html
