HTTP Server (Custom) icon HTTP Server (Custom) — HTTP server for ARC serving HTML/CSS/PNG/JPG from ARC/HTTP Server Root; supports AJAX tags (ez-move, ez-script, ez-camera) to control the robot. Try it →
Robot Goes Crazy By Itself! Help! Very Important!
Hello, I need assistance in understanding why my robot is controlling itself. It is supposed to be controlled from a laptop keyboard and it works fine at times but at VERY IMPORTANT times it starts to go crazy like its spazzing. I was testing my teams robot in the operating room at our local hospital to see if it would work with the robotic microsurgery equipment but it kept going crazy! We are trying to use the arm to help with the irrigation that goes on during surgery. Attached below is a video of the situation but the arm gets worse at times. I figured out that one of the arms joints is most likely the cause but it would be helpful to here other peoples opinions to help solve this problem. Please respond asap, it would be much appreciated!
Rich, Thank you for responding. Do you have a link where I can purchase them? I will try google, Ebay.
Thank You Steve S
Ireland
Get a few different colours they look very impressive, I use red for EZ supply & blue for servo's
search for voltage meter
Bravia, Thank You, I will do that. Steve S
Okay I will try the voltage check and post my results. Thanks to everyone that is helping me with the problem. I greatly appreciate it!
I love the adjustable regulators that have the built in lcd:)
@Martin , I am just checking in. It looks we we able to offer some good suggestions. I'm trying to clear out some of the old questions. Do you mind marking the thread as answered? Thank you
#15
Remember it is not only the voltage that is important, also the curret carrying capabilities. That is where the "hump!" comes from. Make sure your battery is strong enough with enough Amphours.
my 2 cents.;)
#16
OH! Make sure your not plugged into the Gnd port between D13 and D14. It can short out the board.
