Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
England
Resolved Resolved by Toyhackrobotics!
Robot Only Turns One Way
Afternoon All. I am using Ultrasonic radar which scans and displays reds dots ok. Also 4 wire H bridge which operates in all directions ok. But when used together the Bot goes foreward and backward fine but only turns in one direction. All check boxes are ticked on the radar config screen. What am I missing? Any help would be appreciated folks!
England
Thanks to all for suggestions. I tried different sensors with better results so putting it down to suspect device.
England
NEWAGETOMY you are a credit to the forum and deserve the credit. Thread can be closed now. (Can't see where to close it)
@WESTIE's- Aw you have made my night after reading that, thanks very much westies.:D
