Arduinocoms icon Arduinocoms — EZB v4-Arduino I2C bridge for ARC: supports custom C# code and reads gamepad or Wii controller inputs for robot control Try it →
Robot Vs. Robot
Has anyone here thought of building a pair of robots that hunt each other? Maybe hack some Laser Tag toys and mount them on the bots (think tank style turrets) so they can score points against each other? They could prowl the house searching for each other to do battle. There would need to be some clever rules to this type of action so they don't just sit in one place shooting at each other till their batteries ran out. Here are some ideas: - The bots would have to be able to somehow sense or detect each other. Maybe by several different types of sensors. Sound, light, IR, video, color, etc. - A certain number of hits within a short time period would cause the bot who's taking the
damage to try to run and hide in another room. - Certain amount of wait time between shots so bots can have time to execute evasive maneuvers. - Each laser hit would give a random number and each number could mean a different level of hit points or damage. - Depending on the level of damage the bot could be programed to simulate damage to certain parts. For example: a bot takes a hit and a random number is generated. Say the number is a six...the six means that the bot took slight damage to the right side drive motor. A script could be executed that would cause the right side H-Bridge to be somewhat slower causing the bot to have difficulty trying to maneuver or stay on course for x number of seconds then it goes back to normal operation. Or a certain number could mean the loss of a certain sensor for x number of seconds giving the robot a disadvantage in battle. - If enough time has elapsed between hits the damage heals and functions become normal until the next battle. - Maybe give them some clever dialog to say while they are doing battle.
The list could go on and on. Anyone think this is a cool idea?
If you get too much interference from ambient light you may have to go a modulated IR like TV remotes use. Adafruit has a IR sensor https://www.adafruit.com/products/157 that detects a 38KHz IR signal. A 555 timer can generate the 38KHz for the transmitter. Circuit diagrams a around on the internet like https://www.electrosome.com/ir-transmitter-receiver-led-tsop1738/ .
There are also https://emartee.com/product/42243/Wrobot%20Digital%2038KHz%20IR%20Sensor%20Kit. Not familiar with them but they look like a possibility.
