Microphone icon Microphone — Record audio from your PC mic, auto-trigger and edit sample rate/effects, then play or export recordings to an EZ-B v4 SoundBoard for robot playback. Try it →
Resolved Resolved by Rich!
Roli Robot Questions
With the roli robot would I be able to use higher mAH like traxxas or these duratrax 7.4v 4,000 mAH batteries https://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBPGW&P=0 and still be ok? Also is there a way I can use one 14.8v battery instead of two 7.4v batteries?
Germany
I am also fine with only one charger and some arms instead;)
I'm a little curious about this one too. So Roli requires two batteries but is only going to ship with one? When I order do I need to add another one to my order?
This thread is out of date. Roli will come with 1 LiPo battery. There will be room for two battery's if you wish to add a second.
Gibraltar
I'ed forego battery for arms anytime but the order at the time did state 2 batteries and two chargers
Germany
Same for me. It even was the reason to buy the Roli.
