Screen Recorder icon Screen Recorder — Record your screen to WMV1/WMV2/H263P files with selectable bitrate, save-folder and start/stop controls, creating tutorial or demo video snippets. Try it →
Roli Rover Exosphere Compatibility
Hello,
I'm trying to use Exosphere and would like to know whether the Roli Rover is compatible with Exosphere.
For clarity, are you asking about compatibility with Synthiam Exosphere for use with an ARC project? Also please specify how the Roli Rover is connected or controlled (for example: via an EZB/compatible robot controller, a different microcontroller, USB, Bluetooth, or a network device) and the exact model or controller board used on the rover.
Thank you, Manisha
Roli Rover by EZ-Robot
Roli Rover with Synthiam ARCx: drive with live video, control arms, follow faces, patrol, and program with Blockly or Python
Exosphere by Synthiam
Telepresence and remote control for any robot with human-assisted tasks, video, audio, and AI training via ARC and mobile devices
All robots using ARC are compatible with exosphere as long as there is a movement panel. Roli default project has a movement panel.
Yes - Roli Rover is compatible with Exosphere as long as it’s being controlled in ARC and the project includes a Movement Panel.
Since the default Roli Rover project already includes a movement panel, it can be used with Exosphere right away.
Typical setup
  1. Open your Roli Rover project in ARC
  2. Make sure a Movement Panel is present and working
  3. Add the Exosphere skill:
    Project Add robot skill Machine Learning Exosphere
  4. Add the Camera Device skill if you want live video for telepresence
  5. Configure Exosphere and submit the task
Important note
Exosphere works with any ARC robot project that has a Movement Panel - it’s not limited to a specific robot model. So if your Roli is already driving correctly in ARC, you’re in good shape.
If you want, I can also walk you through the exact ARC steps to set up Roli Rover with Exosphere and camera streaming.
