this one catsh my eye .i have a few questions.
will there be other colors availeble in the future. is it possible to ad a lcd in chest whit image/video what he sees. does the tail fit on the rover body shell
thank you
Robot Skill To Camera
— Capture a robot skill's display and stream selected area as video to a configured camera device with FPS and live preview crop.
thank you
is parts waist JD and under body to by ?
I used the Rover base in bodies to substitute for the treaded track. and put the rover cover on top of it. The body os the jd biped body.
Well, that's quite a plan you have there. I'm fairly certain that the JD-to-Roli body EZ-Bit isn't available yet, but maybe soon. (they probably still have the 3D model)
The JD body will slide in where the camera servos are attached.
The JD body has two female connectors, and to make it worse the roli body has a female connector on the part he wants to click it on to. The robot in the picture is using a 3d-printed connector (designed by niek, if I remember correctly).
yes thats correct.
Wow, that IS my adapter
yes it looks very good on the rolli.is on sale?
