Sighthound Cloud API icon Sighthound Cloud API — Cloud-based detection of people and faces in robot camera video; returns locations, gender, age, pose, emotion, plus 68-point facial landmarks. Try it →
Roomba Movement Panel Sensor Interaction
Hi Athena,
I'm curious if the "iRobot Roomba Movement Panel" skill in Synthiam ARC utilizes the Roomba's wheel encoders during navigation? Understanding how the skill interacts with the Roomba's sensors will help me optimize its movement in my project. Thank you!
Roomba by iRobot
Synthiam ARCx turns iRobot Roomba into a drivable robot with scripts, sensors, browser control, and AI-ready robotics skills.
Controller Dependant
Servos ✕
ADC ✕
Digital ✕
Control Roomba/Create via ARC: drive, stream sensors, read encoders, configure COM/HW UART, and send pose to NMS for mapping/navigation.
Hi there!
Yes, the iRobot Roomba Movement Panel skill in ARC does make use of the Roomba’s wheel encoders for navigation-but with an important condition.
How It Works:
  • Bidirectional Communication Requirement:
    The skill utilizes the wheel encoder data only if you are using a bidirectional connection (either via the PC COM Port or the hardware UART on the EZB). These connection types let ARC both send commands and read sensor data concurrently. If you’re using a one-way connection (such as Software Serial using only the RX line), the sensor data-including the wheel encoder counts-won’t be available.
  • Wheel Encoder Integration:
    When using a bidirectional setup, the Roomba’s onboard wheel encoders (typically around 508.8 ticks per revolution) are streamed back to ARC. The Movement Panel skill then uses this odometry data to calculate the robot’s current position in Cartesian coordinates. This data can be pushed into ARC’s Navigation Messaging System (NMS) for mapping and further navigation improvements.
  • Optimizing Navigation:
    With the wheel encoder data available, you can better monitor and optimize your robot’s movement. For example, if you plan to use waypoint navigation or integrate mapping skills (like The Navigator), be sure to enable sensor streaming in the configuration. This ensures that the used encoder values are continuously updating the internal odometry, which helps compensate for any drift during longer runs.
For more details on sensor streaming and the required connection types, you may want to review our Roomba support documentation here:
Roomba Hardware Support.
Do you have any further questions about setting up the sensor streaming or optimizing your Roomba's navigation? Happy to help!
Germany
it means also we can not use the intel t265 in this case, right ? both sensors  wheel encoder and intel t265 are in the same group L3G2.
#3   — Edited
If you’re asking Athena, you have to tag her name in the message. But I can respond - yeah you can’t use both lose hint types.
I mean, you could try but the data is gonna be wonky. The wheel encoders slip, and the t265 drifts. So even if they were to be calculated off each other, both are always incorrect.
The reason why the slam can generate an accurate pose is because it uses known landmark characteristics. So comparing against the slam pose is going to give you an almost near perfect pose value. The pose hint gives the slam an approximate place to begin looking for where the robot could be on the map. The slam does the rest.
We’re still thinking about the t265 wondering if the position needs to be reset to home every few seconds - if that helps compensate for the drift.
We have seen that t265 slowly start drifting so bad that our robot thinks it’s outside. That’s why you generally see commercial robots using outside in pose sensors (cameras or sensors in the room). But the other option for inside out pose sensors is having multiple scan angles and combining multiple slam maps. But that’s starting to get super cpu or gpu intensive
