Is it possible to rotate the camera input feed by 180 degrees?
The camera circuit board will fit better on my robots face if it can be mounted upside down.
Sketch Pad
— Script-driven Sketch Pad for ARC: draw shapes, text, lines and faces via controlCommand() to visualize object locations, paths and robot data.
Yep... look in the camera control config to change the camera orientation....
OK cool - found it. Thanks.
