Hello...
I use ARC but couldnt connect rover 2.0. show this report,
13.06.2014 22:39 - Rover Error: System.IO.IOException: Aktarma baglantisindan veriler okunamadi: Baglanilan uygun olarak belli bir süre içinde yanit vermediginden veya kurulan baglanti baglanilan ana bilgisayar yanit vermediginden bir baglanti kurulamadi. ---> System.Net.Sockets.SocketException: Baglanilan uygun olarak belli bir süre içinde yanit vermediginden veya kurulan baglanti baglanilan ana bilgisayar yanit vermediginden bir baglanti kurulamadi konum: System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) konum: System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- Iç özel durum yigini izlemesinin sonu --- konum: System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) konum: System.IO.Stream.ReadByte() konum: EZ_B.BrookstoneRover.Connect()
you can help me ?
thanks...
Thanks for all info. But I still do need your support. Please help. Thanks in advance.
@Acemalt... You'll have to be patient then... As mentioned Version 2 of the Rover is currently not supported yet... EZ Robot will need time to get version 2 of the Rover working....
Thanks I wait
Wow,, I didn't know it took so long to send something to Canada, from the US.
It isn't the shipping, it is the customs office (primarily). Fedex or DHL can reduce the time vs USPS to Canada Post, but at fairly high cost.
Well that took a bit, but it should be there.
CC
Got it!
Super!
