Feetech RS485 Servo icon Feetech RS485 Servo — Control Feetech serial bus smart servos via EZB UART or PC COM port in ARC using virtual ports mapped to servo IDs. Try it →
Rss Feed Unstopable
It seems an Rss feed is unstopable until it reaches the end. A "ScriptStop" will try to stop it, but will only lock it up with "(highlighted in green) Stopping". I would like to stop the SpeakRSS whenever I wanted rather then wait until it normally ends, with a Script command or an EXEC. Any leads/suggestions would be appreciated! Glen from Salt Spring Island
I am presuming it gets put in a Temp file somewhere and will continue until the end of the file
Thank you so much DJ! I appreciate all the hard work and dedication you put into EZ-Robot AND into addressing problem issues in a timely manner! Glen from Salt Spring Island
