Rafiki Front Bumber icon Rafiki Front Bumber — Rafiki front bumper plugin: reads 4 proximity sensors via serial, updates ARC variables, blocks motor movement toward detected obstacles for SLAM Try it →
Rss News
Hey guys, here is a script I have been working on. It reads the Rss News and after it is done with the first story it asks you if you want to continue. If you say "Yes" it will continue to the second story, and if you say "NO" it will end the script. I didn't know if this was posted already somewhere but I thought I would share it anyways . RSSNEWS.EZB:D
#25
I thought that's what the error message meant. You assume correctly, I do have my system set up for English GB. I don't fancy re-training my speech rec so I looked at going a different way.
I found the RSS jokes in ARC examples, put in BBC's news rss and worked fine, but where and what do I put so while the feed is being read, I can say something like "stop reading" to the voice rec and it does just that? I tried a few different ways but none of them worked. Any ideas?
Cheers.
#26
Just to elaborate on the question I posted above, I am trying to find a way to stop an RSS feed from being read out at any point while it's being read by using a speech recognition control, and so far have not had any luck. I have tried script commands such as,
Stop Audio, Speak Stop, Control command scrip stop, Control command script pause, and Control command script start for the RSS stop script control in the RSS jokes example.
Non of which which will execute until the entire RSS feed has been read. The manual stop script control works fine but would love to do this via speech recognition. Still being new at scripting I am out of ideas to how I can achieve this so any ideas would be most welcome.:)
