Auto Position Movement Panel (Gait) icon Auto Position Movement Panel (Gait) — Create servo frames/actions to animate humanoid, hexapod or custom gaits with smooth transitions, SW ramping and directional control Try it →
Ruined A Ezb4 Before I Even Started
Has anyone had this happen to them?
Tried installing the comm upgrade board onto the EZB today, noticed once plugged in there was no power except for a very faint red led.
I noticed the pins weren't making contact to get power, they were bent from me not being careful enough, but trust me i did this slowly, but not slow and careful enough it seems..
Anyway i broke a pin trying to straighten it. Sad thing is i had everything ready to start my build this weekend and i now have no brain.
Is there anyway it can be fixed?
Im sure its dead now, hard lesson learnt, will just make sure i buy an ezb4 that doesn't need the comm upgrade. If anyone else has to this please be careful, its not as straight forward as it looks...damn those tiny little pins...
I have upgraded 6 of my old ezb4 boards will no issues... Pretty straight forward
I separate my ez-b a fair amount and have no issues. Possibly the pins were bent Turing packaging or shipping slightly which knocked the alignment out.
Thanks for the replies guys, going to get my soldering iron out to see if i can get another pin in there, if not then will just order another one.
The board can be fixed, You will have to carefully with a razor knife or dremel, cut the pin strip on each side, then on solder the pin. Then solder a new pin in place. you will have to be real careful not to over heat the board. I do this sort of stuff all the time. The repair not the pin breaking.
Richard Z
Good luck, Take your time. I would not try to remove the old solder, Use some Alcohol to clean the board first, then heat up the solder and pull the pin out (after you cut the strip apart). If you find that the solder does not melt, add a little fresh solder to help the heat transfer. Use a well cleaned and tined iron tip.
@NEWAGETOMY The pin that is missing in the picture won't effect the overall operation of the EZ-Bv4. The pin that is missing is D20 and everything should be operational besides a missing digital pin.
@rz90208 is absolutley correct, if you can't go without D20 I would also remove and repair the single pin itself just as he mentioned.
We've implemented a solution to prevent this kind of thing from happening in the future, it will just take time for the newest production runs to work their way into circulation.
Oh wow, i did notice it was difficult to open mine as well, i was very careful too but all the pins on one side slightly bent after taking apart,lucky when i put back together they all still fit in place.I had to order a new bottom board (blown from my own mistake earlier) which should arrive in a few days,now I am worried about taking it apart again to fit the new bottom board. I will be so paranoid,LOL!
