Connection Diagnostic icon Connection Diagnostic — Diagnose EZ-B Wi-Fi connection issues with verbose EZ-B communication logging, ping tests, log export and diagnostic reports for Synthiam support. Try it →
Why can only one script be run at a time? You can run a lot of scripts at the same time. You can also have one script start, stop or pause another script with control commands.
You will want to use a ControlCommand in the script with the saywait() command which will start the jaw script, the jaw script should be looping so it's always moving while talking and then once the talking is finished use another ControlCommand to stop the jaw moving.
Something like this... ("Script" is the name of the script you want to start and stop)
ControlCommand("Script", ScriptStart)
SayWait("This is some jibber jabber")
ControlCommand("Script", ScriptStop)
@Frank.... try and post your "scripts" to allow further inspection!:)
