Running Your Bot Through A Custom Website/http Server Layout
Running Your Bot Through A Custom Website/Http Server Layout
Hey guys. Little project I want to look into.
As I mentioned in this thread, I want to make a webpage/custom web server layout and run the ez-b through this. I have html background, so designing the webpage should be no problem, but I know little of getting ARC stuff into that page. I tried setting up the http server but it wouldn't work. So, who's up for helping me try this?
#49
Without the encode script. Thanks so much for the help Chrissi! Its up to me now to get the page figured out!
Now, is jquery java script? Because the I could make a separate java file so the html isn't as cluttered.
Thanks! Tech
#50
Yep, jQuery is a Javascript library (not java :P ). 99% of the time if you see a script in an HTML page it's Javascript! So you could just put it all in a js file.
#53
Thanks DJ. I'll take a look at it. I'll release my setup depending on how the new server works.
