Miscellaneous Utility Plugin icon Miscellaneous Utility Plugin — ARC utilities: DataQuery for SQL/ODBC/OLEDB/Excel with parameterized queries returning array variables; Ticks/Millis timing functions. Try it →
STL doesn't match print
STL Doesn't Match Print
i printed the backpart of a lever servo,and i notest the file is not correct with the print? i notest some other parts doesn match.
JD Humanoid by EZ-Robot
Relative Servos by Synthiam
Synchronize servos by designating a master; slave servos mirror scaled (decimal/negative) positions with min/max limits and pause control
They match perfect. The image is a render of the stl.
i just notest there is another stl p23-01 is the good one. whats this file for?
thank you dj
