Command Duplicator icon Command Duplicator — Duplicate and synchronize commands from one master EZ-B to multiple slave EZ-Bs for simultaneous, mirrored robot actions. Try it →
Resolved Resolved by ptp!
Sabertooth 2x32 Controller Voltage Question
Sabertooth 2X32 Controller Voltage Question
Hi All, I am working on a wheelchair based robot that utilizes 2 24 VDC motors and will be controlled by EZ B V4 controller and a Sabertooth 2X32 motor controller. The problem Im having is that when I hook up the positive 24VDC line to the Battery + terminal I get positive potential through all remaining terminals. So, basically if I put a volt meter probe on the detached negative and the other on and sabertooth controller terminal I get 24VDC, which I think would cause a short. I tried calling and emailing Sabertooth Tech support with no response for a couple of days, so any help at all is highly appreciated ?
Thank you.
#25
Ok Dave. I appreciate yours and everyone else contribution in helping answer my questions. I plan on becoming an active member of the forum as from previous threads I read were very Informative. You're a great bunch of fellow robot enthusiasts and I look forward to sharing my progress pics from the robot I am building.
Thanks, Rob
