Live Stream Receiver icon Live Stream Receiver — Play live web video and audio streams inside ARC from Chrome/Firefox, streaming directly to ARC camera control; network configuration may be needed. Try it →
EZB to Sabertoorh Ground to Ground (ov) VCC to 5V Signal to S1
Motors to Sabertooth As sabertooth instructions - I assume you have it drawn correctly.
Battery to Sabertooth As sabertooth instructions. Assuming you have it drawn correctly.
If using multiple voltage sources all grounds must be connected as a common ground (as you have shown correctly however may not be needed if the ground on the sabertooth is common, it wont hurt putting it in anyway)
So yes, I think your picture is correct.
i read there was something about grounding the signal from the ez-b by the 0V input on it.
ill see if i get any other comments
Your picture is correct:)
The Sabertooth (at least the 2x25) also has a 5v output that can be used to power the EZ-B so you don't need 2 power sources. But your diagram will work as is.
Hi guys! Im not sure if I am supposed to post like this but is this sabertooth/EZ-B wiring done correctly?
Thanks!
Looks good to me from what little I know about the sabertooth - all that is required to the EZ-B is the signal wire and a common ground on the whole lot.
I assume the dip switches are set correctly (can't quite make them out)
