ADC Meter icon ADC Meter — ADC VU meter displaying 0-3.3/5V as a 0-255 linear meter; configurable board/port, sampling interval and color; pausable real-time readings. Try it →
Sabertooth/kangaroo With Different Motor/encoder Combination
Sabertooth/Kangaroo With Different Motor/Encoder Combination
Since I know some of you have used the Sabertooth and Kangaroo I figured I would ask opinions.
I have decided on the Parralax Arlo base for my next robot chassis. I will use the caster's from parralax.
I will most likely be using the Sabertooth and kangaroo combination for motor controller/PID but I am not decided on this and open to suggestions.
I also find myself in a heated mental debate between the wheel/motor combination from parralax or the Zagros Rex motors and wheels combined with the Sabertooth/Kangaroo.
Item 1:
One of the key items for me is how well the encoders between the two different motor/wheel sets works with the Sabertooth and kangaroo.
Item 2:
The other item floating in my mind is the ground clearance between the two motor/wheel sets. It seems at least to me that the Zagros wheels would provide more ground clearing but since the base plate of the chassis provides stability to the base platform I am not really sure if using the Zagros motors are feasible.
Item 3:
Since I am going to build a body, arms and head on top of the base the torque and weight carrying ability is important.
Item 4:
I need to be able to control both the position and speed of the motors at the same time. For example example I should be able to have to robot move lets say 1 feet at a certain speed.
I know this is kind of an open ended questions but if anyone have used any of these wheel/motor combinations please provide your 2 cents as it relates to the items listed above.
I appreciate any comments or insights you guys can provide.
David,
can you make a simple draw how you hook the encoders, 4013 and the connection to the arduino, every tiny detail (from pin to pin)
Do it by hand to be quick.
#114
I will get this to you. give me a bit of time and I will upload it. Work consuming quite a bit of time right now. Im in meetings from 3 until 5 CST today so will get it out as soon as I can.
#115
This is what I built to wire off of. The student will come up with a sound design:).
Above the 4013 is a 104 disk cap.
The connection to the arduino is going through the Roo pins right now. A - 5 B - 2
    • vcc on opposite side of board
    • to ground where pin 1 would be
#117
David, just throwing this out there... Knowing you already have your equipment. I don't have specifics with me at work but I do know my roboclaw motor controllers support encoders natively on board, not extra boards. The roboclaw also has a USB port native to it. I mention this due to several of our past conversations. It may be something for you to take a look at. Chris
#118
Thanks you Chris, I will look into it. I am on a mission to solve this issue and the roboclaw might solve it for me, but my head isn't sore enough yet from banging it up against the problem:)
David,
Do you have this PCB already, or are staging the circuit in a breadboard ?
#120
Breadboard. This was the quickest thing I could get you to show how it is wired in the breadboard.
