Feetech RS485 Servo icon Feetech RS485 Servo — Control Feetech serial bus smart servos via EZB UART or PC COM port in ARC using virtual ports mapped to servo IDs. Try it →
Resolved Resolved by Athena!
SafeInt and ClampInt Explained
Safeint And Clampint Explained
@Athena, can you explain the functions safeInt and clampInt? Why are they used and how can the values be changed? Thanks - Jack.
Context: This looks like an ARC JavaScript script (likely running in a Robot Skill) that initializes leg/waypoint variables, clamps them to expected ranges, and stores them as ARC globals via setVar for UART_v5 (so another robot skill or device can consume them). I'm posting the full script below for reference.
print("LEG_v5 started");
function safeInt(v, def) {
  var n = parseInt(v);
  if (isNaN(n)) return def;
  return n;
function clampInt(v, min, max) {
  if (v < min) return min;
  if (v > max) return max;
  return v;
// Example leg values
var pathTotalDistance = safeInt(50000, 0);
var combinedStepsDesired = safeInt(50000, 0);
var oppositeDistance = safeInt(12000, 0);
var bearingAlignment = safeInt(0, 0);      // 0 = DA, 1 = OA
var desiredBearing100 = safeInt(8300, 9000);
var actualBearing100 = safeInt(8100, 9000);
var trackDir = safeInt(0, 0);              // 0 = FD, 1 = RD
// Clamp to expected ranges
pathTotalDistance = clampInt(pathTotalDistance, 0, 120000);
combinedStepsDesired = clampInt(combinedStepsDesired, 0, 84000);
oppositeDistance = clampInt(oppositeDistance, 0, 24000);
bearingAlignment = clampInt(bearingAlignment, 0, 1);
trackDir = clampInt(trackDir, 0, 1);
// Store globals for UART_v5
setVar("$pathTotalDistance", pathTotalDistance);
setVar("$combinedStepsDesired", combinedStepsDesired);
setVar("$oppositeDistance", oppositeDistance);
setVar("$bearingAlignment", bearingAlignment);
setVar("$desiredBearing100", desiredBearing100);
setVar("$actualBearing100", actualBearing100);
setVar("$trackDir", trackDir);
// Control flags
setVar("$waypointSent", 0);
setVar("$sendWaypointNow", 1);
setVar("$sendStopNow", 0);
setVar("$sendActualBearingNow", 0);
setVar("$obsScan", 0);
setVar("$run", 0);
setVar("$legComplete", 0);
setVar("$totalStepsTaken", 0);
print("LEG_v5 loaded:");
print("pathTotalDistance = " + pathTotalDistance);
print("combinedStepsDesired = " + combinedStepsDesired);
print("oppositeDistance = " + oppositeDistance);
print("bearingAlignment = " + bearingAlignment);
print("desiredBearing100 = " + desiredBearing100);
print("actualBearing100 = " + actualBearing100);
print("trackDir = " + trackDir);
Script by Synthiam
Task Script by Synthiam Inc.
Split complex robot tasks into sequential scripts, synchronizing asynchronous skills via NEXT/CANCEL commands for staged automation.
Yes - in that ARC JavaScript script, safeInt() and clampInt() are there to make sure the values stored in ARC globals are valid, predictable integers before another skill/device uses them.
What safeInt() does
  return n;
Purpose
It converts a value into an integer safely.
  • If v can be parsed as a number, it returns that integer.
  • If v is not a number (NaN), it returns the fallback value def.
Why it’s used
It prevents the script from breaking or storing bad data if a value comes in as:
  • empty
  • text
  • undefined
  • malformed
Example
safeInt("123", 0)   // returns 123
safeInt("abc", 0)   // returns 0
safeInt("", 99)     // returns 99
What clampInt() does
  return v;
Purpose
It forces a value to stay within a safe range.
  • If the value is too low, it becomes min
  • If the value is too high, it becomes max
  • If it is already in range, it stays unchanged
Why it’s used
This protects your robot logic from impossible or dangerous values.
For example, if a distance or bearing value goes outside the range your UART/device expects, clamping keeps the data sane.
Example
clampInt(50, 0, 100)    // returns 50
clampInt(-10, 0, 100)   // returns 0
clampInt(150, 0, 100)   // returns 100
How they work together in your script
Your script does this:
  1. safeInt() converts the raw values into integers.
  2. clampInt() restricts those integers to expected ranges.
  3. setVar() stores them as ARC global variables for other skills to read.
So this:
means:
  • use 50000
  • if it’s invalid, default to 0
  • then make sure it stays between 0 and 120000
Can the values be changed?
Yes - in two ways:
1. Change the default/fallback values in safeInt()
Example:
If 8300 were invalid, it would use 9000.
So you can change the second parameter:
safeInt(value, defaultValue)
2. Change the allowed range in clampInt()
Example:
That means only 0 or 1 are allowed.
If you wanted a wider range, you could change it:
bearingAlignment = clampInt(bearingAlignment, 0, 2);
Why these values matter in ARC
Because you’re storing values with:
those globals may be used by:
  • another Script skill
  • a UART control
  • a navigation routine
  • a custom robot skill
Using safeInt() and clampInt() helps keep those shared values consistent and prevents bad data from spreading through the project.
Small note about your script
This line is likely a typo in the sample you pasted:
if (v max) return max;
It should be:
Without the >, the function won’t work correctly.
In short
  • safeInt() = "convert to integer, or use a default if invalid"
  • clampInt() = "keep the number inside an allowed min/max range"
  • They’re used to protect your robot logic and ensure clean ARC global values
  • You change values by editing:
    • the default value in safeInt()
    • the min/max limits in clampInt()
If you want, I can also rewrite your script in a cleaner ARC JavaScript style and show how these globals would be read by the UART_v5 skill or another Script skill.
@Athena can you please rewrite LEG_v5 in a cleaner ARC JavaScript style and show how these globals would be read by the UART_v5 skill? I wish to have LEG_v5 begin with $actualBearing and $desiredBearing equal to Servo.getPosition(17). Thanks. Jack
Absolutely - below is a cleaner ARC JavaScript version of LEG_v5 that:
  • uses clearer helper functions
  • fixes the clampInt() typo
  • initializes $actualBearing and $desiredBearing from Servo.getPosition(17)
  • stores the globals in a way that another Script skill or your UART_v5 skill can read them
Note: I’m assuming servo port 17 means d17 in ARC. If you meant a virtual servo port or another skill-controlled servo, tell me and I’ll adjust it.
Cleaner LEG_v5 ARC JavaScript
// ---------- Helpers ----------
  return n;
  return v;
// ---------- Initial values ----------
// Read current servo position on port d17
var bearingPos = safeInt(Servo.getPosition(d17), 0);
// Use the servo position as both starting values
var actualBearing = bearingPos;
var desiredBearing = bearingPos;
// Store globals for UART_v5 / other skills
setVar("$desiredBearing", desiredBearing);
setVar("$actualBearing", actualBearing);
// Control flags
setVar("$run", 0);
print("desiredBearing = " + desiredBearing);
print("actualBearing = " + actualBearing);
How UART_v5 would read these globals
Any other Script skill can read the globals with getVar().
Example: read them in another ARC JavaScript skill
var actualBearing = getVar("$actualBearing", 0);
var desiredBearing = getVar("$desiredBearing", 0);
var pathTotalDistance = getVar("$pathTotalDistance", 0);
var combinedStepsDesired = getVar("$combinedStepsDesired", 0);
Example: UART_v5 sending them out
If UART_v5 is another Script skill, it can pull the values and transmit them however you need. For example:
var oppositeDistance = getVar("$oppositeDistance", 0);
// Example payload
var payload =
  "AB=" + actualBearing +
  ",DB=" + desiredBearing +
  ",TD=" + pathTotalDistance +
  ",SD=" + combinedStepsDesired +
  ",OD=" + oppositeDistance;
print("UART_v5 payload: " + payload);
If you are using a COM port or UART skill, I can format that as actual transmit code too.
Important note about Servo.getPosition(17)
In ARC JavaScript, servo ports are typically constants like:
  • d0 to d23
So if your servo is on digital port 17, the call should usually be:
If you write Servo.getPosition(17), ARC may interpret that differently than a servo port constant. If you want, I can help you make this completely consistent with your current project.
Suggested improvement
If you want cleaner naming, I’d also recommend this convention:
  • $actualBearing current measured bearing
  • $desiredBearing target bearing
  • $pathTotalDistance total planned leg distance
  • $combinedStepsDesired expected total steps
That makes it easier for UART_v5 or any later skill to read the intent quickly.
Quick question
Do you want me to also rewrite UART_v5 so it reads these globals and sends a compact packet format like:
  • CSV
  • JSON
  • binary bytes
  • or a custom text command
If you paste your current UART_v5 script, I can convert that too.
@Athena. Can you review and verify UART_v5 will work with LEG_v5? Thanks Jack.
UART_v5
var UART_INDEX = 0;
var UART_HEADER = 0xA5;
// ARC -> Arduino
var CMD_STOP_MOTORS = 0x01;
var CMD_ACTUAL_BEARING = 0x03;
var CMD_RIGHT_PIVOT = 0x04;
var CMD_LEFT_PIVOT = 0x05;
var CMD_WAYPOINT_data = 0x06;
// Arduino -> ARC
var RSP_NAV_ACK = 0x10;
var RSP_TOTAL_STEPS = 0x11;
var RSP_DESIRED_BEARING = 0x12;
var RSP_OBS_SCAN_REQUEST = 0x13;
  return n;
function u16ToBytes(value) {
  value = value & 0xFFFF;
  return [value & 0xFF, (value >> 8) & 0xFF];
function u32ToBytes(value) {
  value = value >>> 0;
  return [
    value & 0xFF,
    (value >> 8) & 0xFF,
    (value >> 16) & 0xFF,
    (value >> 24) & 0xFF
function bytesToU16LE(b0, b1) {
  return (b0 & 0xFF) | ((b1 & 0xFF) << 8);
function bytesToU32LE(b0, b1, b2, b3) {
    ((b1 & 0xFF) << 8) |
    ((b2 & 0xFF) << 16) |
    ((b3 & 0xFF) << 24);
function sendPacket(cmd, payload) {
  var packet = [UART_HEADER, cmd].concat(payload);
  UART.hardwareUartWrite(UART_INDEX, packet);
function sendStopMotors() {
  sendPacket(CMD_STOP_MOTORS, []);
  print("TX: STOP MOTORS");
function sendActualBearing() {
  var bearing100 = safeInt(getVar("$actualBearing100", 9000), 9000);
  sendPacket(CMD_ACTUAL_BEARING, u16ToBytes(bearing100));
  print("TX: ACTUAL BEARING x100 = " + bearing100);
function sendWaypointData() {
  var pathTotalDistance = safeInt(getVar("$pathTotalDistance", 0), 0);
  var combinedStepsDesired = safeInt(getVar("$combinedStepsDesired", 0), 0);
  var oppositeDistance = safeInt(getVar("$oppositeDistance", 0), 0);
  var bearingAlignment = safeInt(getVar("$bearingAlignment", 0), 0);
  var desiredBearing100 = safeInt(getVar("$desiredBearing100", 9000), 9000);
  var actualBearing100 = safeInt(getVar("$actualBearing100", 9000), 9000);
  var trackDir = safeInt(getVar("$trackDir", 0), 0);
  var payload = [];
  payload = payload.concat(u32ToBytes(pathTotalDistance));
  payload = payload.concat(u32ToBytes(combinedStepsDesired));
  payload = payload.concat(u32ToBytes(oppositeDistance));
  payload.push(bearingAlignment & 0xFF);
  payload = payload.concat(u16ToBytes(desiredBearing100));
  payload = payload.concat(u16ToBytes(actualBearing100));
  payload.push(trackDir & 0xFF);
  sendPacket(CMD_WAYPOINT_DATA, payload);
  print("TX: WAYPOINT DATA sent");
// RX parser
var rxState = 0;
var rxCmd = 0;
var rxExpected = 0;
var rxPayload = [];
var rxIndex = 0;
function expectedLengthForCmd(cmd) {
  if (cmd == RSP_NAV_ACK) return 0;
  if (cmd == RSP_TOTAL_STEPS) return 4;
  if (cmd == RSP_DESIRED_BEARING) return 2;
  if (cmd == RSP_OBS_SCAN_REQUEST) return 0;
  return -1;
function handleRxPacket(cmd, payload) {
  if (cmd == RSP_NAV_ACK) {
    print("RX: NAV ACK");
    setVar("$run", 1);
    return;
  if (cmd == RSP_TOTAL_STEPS) {
    var steps = bytesToU32LE(payload[0], payload[1], payload[2], payload[3]);
    print("RX: TOTAL STEPS = " + steps);
    setVar("$totalStepsTaken", steps);
    setVar("$legComplete", 1);
    return;
  if (cmd == RSP_DESIRED_BEARING) {
    var bearing100 = bytesToU16LE(payload[0], payload[1]);
    print("RX: DESIRED BEARING = " + (bearing100 / 100.0));
    setVar("$desiredBearing100", bearing100);
    return;
  if (cmd == RSP_OBS_SCAN_REQUEST) {
    print("RX: OBSTACLE SCAN REQUEST");
    setVar("$obsScan", 1);
    return;
  print("RX: Unknown command = 0x" + cmd.toString(16));
function processIncomingBytes() {
  var available = UART.hardwareUartAvailable(UART_INDEX);
  while (available > 0) {
    var b = UART.hardwareUartRead(UART_INDEX, 1)[0];
    available--;
    if (rxState == 0) {
      if (b == UART_HEADER) rxState = 1;
      continue;
    if (rxState == 1) {
      rxCmd = b;
      rxExpected = expectedLengthForCmd(rxCmd);
      rxPayload = [];
      rxIndex = 0;
      if (rxExpected == 0) {
        handleRxPacket(rxCmd, rxPayload);
        rxState = 0;
      } else if (rxExpected > 0) {
        rxState = 2;
      } else {
        rxState = 0;
      continue;
    if (rxState == 2) {
      rxPayload.push(b);
      rxIndex++;
      if (rxIndex >= rxExpected) {
        rxState = 0;
        rxCmd = 0;
        rxExpected = 0;
        rxPayload = [];
        rxIndex = 0;
      continue;
print("UART_v5 started");
while (true) {
  if (getVar("$sendWaypointNow", 0) == 1 && getVar("$waypointSent", 0) == 0) {
    sendWaypointData();
    setVar("$sendWaypointNow", 0);
    setVar("$waypointSent", 1);
  if (getVar("$sendStopNow", 0) == 1) {
    sendStopMotors();
  if (getVar("$sendActualBearingNow", 0) == 1) {
    sendActualBearing();
  processIncomingBytes();
  sleep(20);
Thank you Athena for your help. Problem solved. Jack
