Notepad icon Notepad — Notepad for ARC: store project notes and connection details in a themed window Try it →
Short answer, no... ARC only runs on a PC... However, you can use ARC (running on your PC) to build an app that will allow you to control your robot from an android device... It's actually pretty easy... So you make the app on your PC via ARC software, then upload to the EZ Robot cloud... You can then download from the cloud to your Samsung or other android device...
OK thanks guys but can you get a divice that runs ez-biulder ?
Yep, any device that runs windows 7 or Windows 8 (but not RT) should run ARC...
Anthony is there a difference between the Samsung galaxy tab 3 pro to the Samsung galaxy tab 3.7.0 ?
They aren't the same wallet lover. The pro has a larger screen , faster cpu and more memory. If you have any version of the tab 3 from Samsung you will be fine though.
Samsung galaxy tab 3 pro to the Samsung galaxy tab 3.7.0, will be able to run ARC mobile.
