Output Audio From EZ-B icon Output Audio From EZ-B — Example ARC skill demonstrating converting, compressing and streaming MP3/WAV to an EZ-B speaker, with play/stop commands and TTS examples. Try it →
Sayezb Does Not Work With Surface Pro
Hi DJ,
I changed my platform to Microsoft surface pro recently. I don't know why the sayezb script does not work with ez-b. Even updated and re-install!
And I have already doubled checked within that forum, but I found nothing to mention about this!
Do you have any ideas be able to solve this issue?
Thanks a lot
  1. Regards Ricky Ma
#33
What servo settings do you need to save?... The webserver just controls the digital IO ports without using ARC... It just controls things like servos and digital IO to test them... there is nothing to save so that's why there is no save button...
now i dont get it.look save button for servo's
You have an old ezb. You should update the comm board to version 2.... The save button you are pointing to with the red arrow only saves the low battery warning option and nothing else... The blue arrow is pointing to controlling the servos only in real time... setting them to 90deg without using ARC that's all... just setting the servos not saving any servo info about tem... Get it now?
As I mentioned the new webserver for the ezb4 x/2 is completely different with more options...
RR
ah yes i get it now.thanks for helping.is it possible that the problem ricky ma has, is become he has no original ez servo's?
am happy with the old version.
#39
Thanks for Justin, Patrick and Richard help:)
hows going with the robot head?
