Train Vision Object By Script icon Train Vision Object By Script — Train camera vision objects via controlcommand(), attach camera, start learning, monitor progress, and return object name for scripts. Try it →
SayEZB only works on Android. On ios it comes out of its speaker.
Not all features of the PC are supported on mobile due to limited hardware, processing capabilities and operating system features.
Also, please ensure you are using the latest ARC before requesting support. When ARC loads, it will flash a window informing you of an update. Your ARC is out dated. It's difficult for anyone on the forum to assist when outdated ARC is used.
DJ,
I do have an android device and SayEZB worked on earlier versions. I have a couple of projects where SayEZB worked great in mobile app on android and these same apps don't work with SayEZB after updating. If you could look into this it would be great ! Thanks again...Rick
Hi DJ,
ARC is updated and SayEZB still isn't working on my android mobile app. It used to work in earlier versions as you said it should. It looks like something has changed since the earlier versions. Any help on resolution of this problem is much appreciated. Again this worked in an earlier version. Thanks much DJ.....Rick :)
Hello DJ,
I updated the mobile app on my Samsung Galaxy S4 and S7. Say EZB works on the Galaxy S4 but still doesn't work on the Galaxy S7. Is there anything you can think of with the Galaxy S7 that would keep the SayEZB command from working? Thanks again. Also wondering if anyone else has this issue? Rick
Due to Android devices having inconsistent OS versions and features between manufacturers and models, EZ-Robot is unable to support all features across all Android devices.
Please update ARC to the latest release before requesting support.
Hello DJ,
My ARC and mobile app are updated. Has anyone else reported this issue with the samsung s7. It is a pretty popular samsung android phone. Is there any chance you can look into this? Thanks again ! Rick
EZ-Robot does not have every Android phone ever made. EZ-Robot does not have the phone you mentioned for development.
Rick, post your project and later tonight I'll try with it and one of my own. I have an S7 Edge, but also have a couple of other Android 6.0.1 devices (Nexus 7 2013, HTC One M8).
What carrier is your S7? T-Mobile and AT&T have started pushing Android 7. Have you upgraded yet? (I am on Verizon and still waiting, but the version could be relevant).
