Tutorial icon Tutorial — Tutorial slide plugin for ARC: create, format and embed text and images per .ezb project; navigate/update slides via ControlCommand; auto-resize images Try it →
Screen Resolution Question
I have just bought a Surface Pro 4 and have been trying all afternoon to set up ARC but just cannot get the resolution to look right - I tried dozens of settings, but all I get is bunched up text as jpeg below.
I have had big screen resolution problems before on my Windows 7 Asus slate tablet which also never worked properly with ARC, is it just me or is there a problem with the way ARC handles screen resolution?
If anyone can help it would be greatly appreciated!
Tony
#17
Yep. Did the trick for me. I guess the secret is to follow directions to set up your system for ARC. That and having a system that falls into spec of what ARC is made to run on.
#18
Any computer manufactured in the last 10-12 years will be able to run the minimum resolution specified for ARC in the instructions located here: https://synthiam.com/Tutorials/Help.aspx?id=207
The challenge isn't resolution when you have older PCs... the challenge is operating system at that point. Anything below Windows 7 is not supported.
#19
ARC and Surface Pro 4 do not get along with each other!
DJ, I carried out the tutorial to the letter
I first tried the tutorial recommendation of 1920 x 1080 text size 125% then rebooted - same problem top lost
I then tried 1920 x 1080 text size 100% then rebooted - same problem top lost
I then tried 1024 x 768, 1152 x 864, 1280 x 600, 1280 x 720, 1280 x 768, 1280 x 800, 1280 x 960, 1280 x 1024 - same problem!
I then tried Daves 1600 x 900 text size 125% then rebooted - same problem top lost
I then tried 1600 x 900 text size 100% then rebooted - same problem top lost
I then tried other settings and none work.
I am absolutely gutted, I have a major ALTAIR robot presentation next week so I bought a grands worth of tablet which would be nice and easy to transport - now I am going to have to strip down one of my main PCs and large monitor to be able to do the presentation. My main Windows 10 PC has no problem with the ARC software everything works as it should, it obviously just does not like tablets!
Why the heck is ARC software so hard to use! It (to me) is really sad that such a great product is being let down by this sometimes seemingly unusable software. I am now very disillusioned!
Tony
#20
Tony,
I am at work where I have Windows 7, so I can't give specific instructions, but Windows 10 has a "Tablet" mode and, when a keyboard is attached (can be Bluetooth), a "Desktop" mode. Have you tried changing to desktop mode?
Windows does all kinds of strange formatting things in tablet mode, and it may be related.
(I don't disagree that only ARC seems to have these formatting issues with Windows 10 at different resolutions. I have dozens, if not hundreds of different apps, and the only one I need to be particular about my screen settings to get to work correctly is ARC. Some may not look good at full screen, but all will work fine in windowed mode, if a little small.... Sorry DJ, but I think you need to stop blaming Microsoft and start looking at the ARC framework and fix this. As more of us get high resolution portable devices, it is only going to get worse).
#21
Thanks Alan, you help and advice is much appreciated on this.
I agree DJ should stop blaming Microsoft, I see this problem as a big flaw in ARC - seriously if I had not invested years of work with EZ-Robot this would have made me give up on the whole idea of using ARC!
I have spent 2 days trying to get EZ-Robot to work on the Surface Pro with no luck - I thought it was supposed to be easy robot, well it seems that it is not very easy to get it to work on tablets.
Tony
#22
The top having blank space with arrange controls is a known issue that I have been struggling to fix since the beginning. If it was that easy, it would be done. This is due to the Control model of ARC by having each control in a window within a window and having a scroll bar. The closest solution I can find per documentation is to disable the scroll bar and force virtual desktops. That isn't an ideal solution but it may be the last hope.
In your current situation, using the virtual desktops is the best option. Right click on the headers of each control and move them to virtual desktops.
As for your original topic, which is font sizing. Please follow the tutorial to adjust font sizing here: https://synthiam.com/Tutorials/Help.aspx?id=207
The font sizing adjusts the size of the text in Windows. Each software application on your computer has space allocated for text. If the font size is increased, the space allocated for the text doesn't fit. This is not an issue limited to ARC and no additional development will be allocated to supporting 150% font size because it will affect those using 100% and 125% font sizing.
The font sizing can be resolved by following the tutorial here: https://synthiam.com/Tutorials/Help.aspx?id=207
If you purchase a tablet or PC that has 150% font sizing, simply follow the instructions to change the font size to 100% or 125%
#23
DJ, please fully read my post #20 - I have done everything over and over from the tutorial https://synthiam.com/Tutorials/Help.aspx?id=207, so the tutorial obviously does not work for a Surface Pro.
As I also explained in the post, I have tried all the permutations of font sizes (100%, 125% etc) for all the screen resolutions and all this has made absolutely no difference!
Tony
#24
The issue i read in post #20 is there is spacing on the workspace above controls, is this correct?
