Kinect Xbox 360 Depth Mapping icon Kinect Xbox 360 Depth Mapping — Converts Xbox 360 Kinect depth frames into NMS obstacle scans for ARC path planning, SLAM, and obstacle avoidance. Try it →
Script Action Upon Motion - Need Help Quick!
Hey all,
Looks like my ping sensor is not working so I need an alternative. I was hoping to use a web cam. Can anyone tell me if possible and how I could trigger a script upon the detection of motion?
Is this even possible with ARC? I'm heading to bed soon, but the competition is tomorrow so I hope to have this fixed in the morning. Judging is at 1pm.
You can see some progress here:
Halloween Display
Thanks for your help! -DaMan
Press CONFIG on the camera control. Select the SCRIPTS tab. You can now edit the Found and Lost script section to execute. :)
Enjoy!
Thanks for the quick reply DJ. Pardon my ignorance, but is there some documentation that describes how these controls work?
I have Tracking Start: controlcommand("Rat", scriptstart)
Number of frames is 2 (started at 8)
I toggle on motion tracking and then move, it tracks me, but the script does not start....
hmmm
I also just tried moving all of my scripts to a scriptmanager so I could use the syntax in the help tab.
Set both Tracking Start and Tracking End to: ControlCommand( "Script Manager", ScriptStart, "Rat" )
no luck:(
You will have to enable motion detection under the Tracking tab
Ah.... Using the examples I was able to determine that my syntax was fine. Restarted ARC and VOILA! Works like a charm now!
Thanks DJ!
